My Vera3 is not working properly, i have a RFXtrx and i have set it up a lot of times, Loaded the alpha10 drivers and finally after severe reboots i had my RFXtrx working with the Oregon Temp / Hygro. Too bad after a few hours the modules doesn't display temperature and Hygro. Remove them again and insalled the complete RFXTRX (and each time reboot) Then i had again 2 modules with Temp and Hygro, but again the next day only the modules but no display of Temp and Hygro. Also the Vera doesn't notify the phone, several times resent notify code, none is working. Finally i did a completa reset and now the modules are gone but the name of the Vera "walbergdomotica" and the password still resist.
How can i complete remove everything (including the drivers that are installed) and get the Vera to factory default?
reset Vera3
Re: reset Vera3
You need to contact MiCasaVerde support and probably also mail them a Picture of Your Vera3 serial number to prove that the Vera is Yours. Thay can reset the system online.
Kind Regards
Dipl. Ing. Thomas Hjorth Nyholm
Etotal IntelliHouse
http://www.etotal.eu
Etotal IntelliHouse
Re: reset Vera3
eeek... online reset by the vendor
Re: reset Vera3
Sounds too nasty, that can't be true.
how about this option I found with 1 single google?
http://wiki.micasaverde.com/index.php/Factory_Reset
ELV FHT80b heating system.
Re: reset Vera3
You can do it yourself have a look at forum.micasaverde.com/index.php/topic,1 ... l#msg93816.
