RFXCOM usb receiver howto add devices
Moderator: RDNZL
gvdham
Post by gvdham »
Not sure wether to post this in domotige or rfxcom but can someone tell me how to add rfxcom devices to domotiga? I attached the usb rfxcom receiver and enabled the module. Now seeing this in the debug log:
002013-06-06 19:51:23 [RFXComRX] Variable Mode => F02C
2013-06-06 19:51:30 C92013-06-06 19:51:30 ACK
2013-06-06 19:51:30 C9C9C9C9C1C1C1C1C1C9C9 bits=73 from SLAVE
2013-06-06 19:53:52 C9DEDEC1C1C1C1C1C9C9C9 bits=73 from SLAVE
2013-06-06 19:54:10 C9D9C1C1C1C1C1C9C9C9C9 bits=73 from SLAVE
2013-06-06 19:54:20 DEDED1C1C1C1DEC9C9C9C9C1C1 bits=94 from SLAVE
2013-06-06 19:54:38 DDC1C1DEC9C9DEDEC1C1C1D9C1 bits=93 from SLAVE
2013-06-06 19:56:05 FBFBFBFBFBFBFBFBFBFBC9DEC9C9C9C1 bits=123 from SLAVE
2013-06-06 19:56:18 C1C1C1C1FBFBFBFBFBFB bits=65 from SLAVE
2013-06-06 19:56:28 FBFBFBFBFBFBFBFBFBFBFBFBFBFBFBFB bits=123 from SLAVE
2013-06-06 19:56:34 FBFBFBFBFBFBFBFBC1D9DDC1C1FBFBFB bits=123 from SLAVE
2013-06-06 20:56:38 FBFBD9DDDEDEC9C1C1C1C1C1
I have powered up two ds10a and found out that connecting the first gives c1 and disconnecting c9.
The ofther gives me a lot fb's both connecting and disconnecting the magnet.
Can somebody give me a clue? Just added a device, x10security, ds10, rfxcom receiver and gave it adress c1c1 but nothing happens.
Help :)
b_weijenberg
Re: RFXCOM usb receiver howto add devices
Post by b_weijenberg »
I suppose the receiver is set to the wrong baud rate.
by default the receiver is set to 4800bd.
But if the receiver is set to 38400bd using the toggle baudrate button in RFreceiver you have to use this 38400 baud or sitch the receiver back to 4800. To do this connect the receiver in RFreceiver at 38400 and click the Toggle baudrate button again.
gvdham
Post by gvdham »
Super, thank u very much!! It works!!
Return to “DomotiGa Forum”
