Been looking here for a long time and just started out with my own project.
I've just stumbeld uppon a problem i just can't seem to figure out.
Tried my dimmer with incontrolHA and everything worked as expected, but i want to use domotiga as my main system.
so installed domotiga, zwave wrapper etc. The stick (Aeon Labs Z-Stick S2) is found, and the added dimmer (FGD-211) is also present in Z-Wave Commander.
Can turn lights on and sometimes off with domotiga.
when i look at the logs, under debug it seems that the stick contineus send a command for a second of 10.
2013-07-27 12:37:02 [Z-Wave] Got value changed notification for node 2 and instance 1 value1 changed to Off.
furthermore the wall switch also stopped working since i added the stick to domotiga
anybody some info on what could be the problem?
Thanks in advance!
