I have DomotiGa running on a pcduino board. Much faster than a RPI.
Used ppa:nemh/gambas3 to install Gambas3.
regards,
m
DomotiGa @ pcduino
Moderator: RDNZL
Re: DomotiGa @ pcduino
I tried to install gambas but I get the following error ....
Any idea how I can fix this? @google I can't find a solution.
I use the latest version 05-31-2013.
ubuntu@ubuntu:~$ sudo add-apt-repository ppa:nemh/gambas3
You are about to add the following PPA to your system:
Gambas 3 release for Ubuntu.
More info: https://launchpad.net/~nemh/+archive/gambas3
Press [ENTER] to continue or ctrl-c to cancel adding it
File "/usr/bin/add-apt-repository", line 160, in <module>
sp = SoftwareProperties(options=options)
File "/usr/lib/python2.7/dist-packages/softwareproperties/SoftwareProperties.py", line 96, in __init__
self.reload_sourceslist()
File "/usr/lib/python2.7/dist-packages/softwareproperties/SoftwareProperties.py", line 584, in reload_sourceslist
self.distro.get_sources(self.sourceslist)
File "/usr/lib/python2.7/dist-packages/aptsources/distro.py", line 87, in get_sources
raise NoDistroTemplateException("Error: could not find a "
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template
You have to edit /etc/lsb-release and replace Linaro with Ubuntu to change the distribution identification.
regards,
m
regards,
m
@marunga:
Any special things to install the OS, Gambas and DomotiGa on the pcduino? Maybe we can make a nice wiki page on www.domotiga.nl for it
Hi redleg,
Do see you have or had the same thing as I am running into.
I followed the tip from Marunga; but that still gives the same error.
Have you got this issue solved already? Then please, share with me.
Thnxs,
Re2go
Thnxs,
Re2go
redleg wrote:I tried to install gambas but I get the following error ....
Any idea how I can fix this? @google I can't find a solution.Code: Select all
ubuntu@ubuntu:~$ sudo add-apt-repository ppa:nemh/gambas3 You are about to add the following PPA to your system: Gambas 3 release for Ubuntu. More info: https://launchpad.net/~nemh/+archive/gambas3 Press [ENTER] to continue or ctrl-c to cancel adding it Traceback (most recent call last): File "/usr/bin/add-apt-repository", line 160, in <module> sp = SoftwareProperties(options=options) File "/usr/lib/python2.7/dist-packages/softwareproperties/SoftwareProperties.py", line 96, in __init__ self.reload_sourceslist() File "/usr/lib/python2.7/dist-packages/softwareproperties/SoftwareProperties.py", line 584, in reload_sourceslist self.distro.get_sources(self.sourceslist) File "/usr/lib/python2.7/dist-packages/aptsources/distro.py", line 87, in get_sources raise NoDistroTemplateException("Error: could not find a " aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template
Hello Re2go,
I am currently on holiday .... I'll try to explain short.
- customize the lsb-release of Linaro to ubuntu
- Get the ppa as shown in this topic.
- Update the packages. (sudo apt-get update)
- Install gambas3 (sudo apt-get install gambas 3)
I can give more info next week when I get home.
Grtz, Redleg
Grtz, Redleg
Hi Redleg,
Thanks, worked out your tips today and got it working now.
Ready now to start selecting an interface and devices !
Thanks for the tips.
Kind regards, Re2go
Kind regards, Re2go
I'm new on this forum.
I have installed domotiga on my pcduino and I'm not an expert!
I use this:
I had this problem and solution:
lifeonubuntu.com/ubuntu-missing-add-apt ... y-command/
Thanks,
Gilles
Belgium
I use this:
$ sudo add-apt-repository ppa:gambas-team/gambas3
$ sudo apt-get update
$ sudo apt-get install gambas3
Thanks,
Gilles
Belgium
Thanks Gilles to confirm this is working for you and what you did to get it working.
All: There is a DomotiGa wiki page on pcduino and it would be great if you can add your tips and tricks here: pcDuino Board.
That way you can benefit and get feedback on how to make the best system based on pcduino.
