CM15Pro and Windows 7
I have two problems with a newly purchased CM15Pro (on Windows 7 Ultimate)
1. I installed the latest ActiveHome software from Marmiteks website, but when I connect the CM15Pro Windows reports it's an unrecognised device. Nothing I do in the way of uninstall/reinstall or refreshing the drivers makes any difference
2. The CM15Pro will not respond to commands from my RF HR10 either (although my existing TM13 is working fine, so I know the HR10 is OK)
ANY suggestions on a next step would be welcome (I've asked Marmitek the same questions, but this forum may give me a quicker answer. I can't believe I am the only person trying this with Win 7
(btw, I've tried my wifes trusty Win XP machine as well - this fails in exactly the same way)
I'm left wondering if I have a duff CM15Pro
UPDATE -:-
I found some suggestions from Marmiteck (which I knew would be a waste of time) but they WORKED and now I can see my CM15Pro from Win 7 (Hooray)
BUT it still does not respond to my HR10 - what might I have done wrong. It's certainly looking like most of this is the dreaded user error
Many thanks
Phil G
UPDATE -:-
Many thanks
Phil G
Re: CM15Pro and Windows 7
Can you switch another x10 device with the hr10 via the cm15?
No not at all
I can switch x10 devices from the pc attached to he CM15 and timed switching works OK
That's all
Is there something I need to set to make the CM15 aware it needs to listen for radio traffic?
That's all
Strange, there is no setting to my knowledge
So either your remote or cm is defect, or a batt problem
But i guess you checked
I'll check the battery, but certainly the remote must be OK
Start Active Hiome Prophilguk wrote:No not at all
That's all
go to Tools > Hardware Interface Configuration.
there you can select the house codes the CM15Pro has to transceive.
When updated, F2 will show you the Activity monitor.
Peter
http://www.pcgsm.nl/
And I have also found (I think) how to use a macro to turn a powerline command into an RF one...
Watch this space (and thanks for the suggestions)
so i can give commands from a rfxcom transmitter to a cm15pro then i dont have to buy a new serial x10 interface for hs3 ?
yes i can
Yes you can
I also found a way to create a macro loopphilguk wrote:And I have also found (I think) how to use a macro to turn a powerline command into an RF one...
Oops
I had a macro looking for C2 ON before issuing an RF C2 ON.....
The RF triggered the macro again (and again and again .........)
Shan't do THAT again
