TP-Link Ethernet converter firmware image
unfortunatelly, I managed to "brick" the TP-Link WiFi adapter. I would like to try flashing the unit or buy a new one locally. Could you please provide the special firmware image?
I just don't want to pay shipping again on a relatively cheap piece of hardware...
Thanks a lot and Merry Christmas!
Radim
Radim
Re: TP-Link Ethernet converter firmware image
Radim,
I have send you the firmware and the manual by mail.
And of course, I wish you a Merry Christmas to!
Hi André,
Can you send me the files as well? I have bricked on of mine too
Could you please tell me if it works?
Thanks
Thanks
- Starting Member
is it possible to get the firmware and manual to ?
i bought the lan version but the gateway is factory, not openwrt and so ...
is it also possible to hook up a hub and use it to connect other usb - rs232 as well ?
Thanks Ronald
Thanks Ronald
Same here, can I be send the correct firmware and manual? Also having problems with my TP-Link.
Could you be so kind to also send me the image?
Hi, could you also send me the image and manual?
I have a TP link: TL-WR710N
Thx.
Thx.
- Starting Member
recently bought with the Opentherm Gateway. I was not able to access the TL-WR710N in accordance with the manual and have reset it. Now it is back to the Openwrt image and I'm not able to use is with the Opentherm Gateway any more.
Your help is much appreciated.
Thx.
Thx.
I would also like to have the files.
Thx in advance
Thx in advance
I would like to recieve the image also. I already had the adapter but did not know I needed another firmware for this.
Thanks in advance.
Thanks in advance.
Unfortunately, I think I have bricked my TL-WR710 as well....
Could someone please post (or mail) the manual and firmware?
Same problem. I guess I shouldn't have used the reset button
Can somebody send me a firmware image and a manual to install it?
Thanks a lot!
Thanks a lot!
Same problem here with the TP link: TL-WR710N.JACDutchman wrote:Hi, could you also send me the image and manual?
Thx.
Also some feedback: This OTGW needs some manual!! Especially with the wireless/LAN interface. The very little manual that was emailed to me has to less information. I followed this manual but it did not work, so i tried some things with trial and error and now I cannot acces the web interface anymore. I'm able to access it through SSH but am not able to get the web interface running again.
hi adre
can you email me the firmware too for the tp-link wr71on v1.2
also pressed the reset button.
