TYTN II
Willem4ever
TYTN II
Post by Willem4ever »
I'm having problems with my TYTN II smartphone, it connects fine using built-in WIFI, get an IP address, but it doesn't get a DNS server assigned.
DCHP server is Internet Systems Consortium DHCP Server V3.0.1. Wireless is in a separate VLAN with helper address configured.
Same DHCP setup works fine for an iPod touch.
-Willem.
TYTN II
what is the radio version of your tytn
I have good experience with version 1.58
Willem4ever
TYTN II
Rom version 1.156.114.4 (09/01/07)
Radio version 1.27.12.11
Protocol version 22.45.88.07H
BTW, it is the T-Mobile 'version' of the TYTN II ....
TYTN II
That's one of the first Rom versions
Versions of my system
ROM 3.14.502.1
Radio 1.65.14.06
Protocol version 25.81.40.02H
Lennart
TYTN II
Post by Lennart »
Hi Willem,
What wireless access point/wireless router are you using? I encountered the same problem with my TYTN II in combination with an (old) Netgear ME102 access point. When I switched over to my wireless Siemens ADSL modem/router (which is also my DHCP server) for wireless access, it worked flawlessly (I used the ME102 because the Siemens modem/router doesn't reach all rooms in our house). The TYTN II did connect with the Netgear ME102, but I had no Internet connectivity. I guess the TYTN II is a little selective in its wireless access (counter)parts? Try a different wireless device to see if it solves your problem, as it may not be your DHCP server...
ROM version: 1.56.405.5
ROM date: 08/28/07
Radio version: 1.27.12.11
Protocol version: 22.45.88.07W
Lennart
Willem4ever
TYTN II
Hi Lennart,
I have full trust in my Cisco AP :-) it does connect, get's an ip address, but fails to get dns ... No problem whatsoever with other devices.
-Willem.
Willem4ever
TYTN II
<br />That's one of the first Rom versions
ROM 3.14.502.1
Radio 1.65.14.06
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">The T-Mobile site has no new firmware available, any other ways to get it updated ??
TYTN II
I have the same HTC TYTN II version as Lennart, Wifi works ok on Draytek Vigor 2950 router.
ROM date: 08/28/07
Did you search the TYTN II forum http://forum.xda-developers.com/forumdisplay.php?f=376
Snelvuur
TYTN II
Post by Snelvuur »
i dont have any issues, but i have my wireless access point forward dhcp request to my own dhcp server build. (so i can also send out tftp adresses and such for my cisco phone)if you have a working dhcp for it, you can perhaps forward it like i do. (if you have that option)
Willem4ever
TYTN II
Well looking at the date it seems my ROM is a little younger 9/1 vs 8/28.
@snelvuur; I'm running my own DHCP server which provides all my devices with successfully with ip addresses, dns, pxe information etc etc.
TYTN II
on the next url are different versions available for download.
I'm using the vista version from april 13.
http://forum.xda-developers.com/forumdisplay.php?f=378
Willem4ever
TYTN II
must be a bug in the version i have, it does a proper request, and it gets a proper response ......
BOOTP/DHCP, Request from 00:18:41:32:0b:ce, length: 305, hops:1, xid:0x23074c85, flags: [none]
Gateway IP: router.dk.eradus.com
Client Ethernet Address: 00:18:41:32:0b:ce
Vendor-rfc1048:
DHCP:REQUEST
RQ:Willem_HTC-1.dk.eradus.com
CID:[ether]00:18:41:32:0b:ce
HN:"Willem_HTC-1"
PR:SM+DG+NS+DN+WNS+WNT+WSC
VC:"Microsoft Windows CE^@"
BOOTP/DHCP, Reply, length: 300, hops:1, xid:0x23074c85, flags: [none]
Your IP: Willem_HTC-1.dk.eradus.com
Server IP: ha-10.dk.eradus.com
Vendor-rfc1048:
DHCP:ACK
SID:ha-10.dk.eradus.com
LT:86400
SM:255.255.255.0
DG:router.dk.eradus.com
NS:ha-10.dk.eradus.com,ha-8.dk.eradus.com
DN:"dk.eradus.com"
WNS:ha-10.dk.eradus.com
Willem4ever
TYTN II
<br />on the next url are different versions available for download.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">HI Chak,
Are you running this on an original TYTN II or e.g. MDA Vario III. I'm tempted to install the Vista version as well.
-Willem.
TYTN II
Yep,
I'm running the vista since few days.
It's running very stable and performance is good.
Before you can install
you need hardspl
http://wiki.xda-developers.com/index.ph ... .Upgrading
Willem4ever
TYTN II
Who can do better .....
