Is the gas meter in holland always with the reflecting 6?? I can see it with my eyes??
I want to make for my elektricty and gas the same schema (van de draaistroommeter), the one in heino's boek, and than connect it to this one http://www.hobby-boards.com/catalog/pro ... ucts_id=42
and i want to read it with digitemp??
Is this going to work?
Measure gas
Measure gas
Hi Kroon,
I think this will work
check out this topic regarding gas metering
http://www.domoticaforum.eu/topic.asp?T ... hTerms=gas
and here also http://www.bwired.nl/Gas.asp
You could also look at the rfxpulse counters http://www.domoticaforum.eu/topic.asp?TOPIC_ID=449
Regards Pieter
Regards Pieter
Measure gas
Pieter,
kan je de relfectie van de 6 met het blote oog zien?
Measure gas
OK now I get you, mean can not instead of can ![Smile :-)](./images/smilies/icon_smile.gif)
Yes you should be able to see the little reflecting space right in the middle of the last digit 6. If you look closely you can see this very clear.
PS: please keep the topic in English.
Regards Pieter
Regards Pieter
Measure gas
Hi ,
Wel i'm looking on the gas meter but nothing on the 6 on the right display, is this possible? I als udes a flash light.
Richard
Richard
Measure gas
It's possible, to bad for you, there are different meters used. Your meter could also be an old one. Perhaps there are members on this board who have the same Gas meter and made a solution.
Measure gas
Has anyone tried or worked with the Voltcraft solution
-Energy measuring (up to 12 sensors)
-Gas measuring
-Base station with USB connection and charting software
http://www.conrad-electronic.nl/nieuwsbrief/129.php
Gas meter: http://www.conrad.nl/goto/?product=125315
Cheers
DJ
-Gas measuring
Cheers
DJ
Measure gas
Have someone tried Optical Meter Reader for Non Pulsed Water, Gas and Electricity Meters
http://www.futumeter.ie/optical-non-pul ... eader.html
I also don't have a mirror on the six or the Zero.
Best regards,
Herbert
Best regards,
Herbert
Measure gas
Hi Herbert,
I couldn't find prices on the link you mentioned, but let's just assume it's not cheap. Maybe you could consider getting another Gas meter. With a reflecting 6, or a Gas meter with a built-in pulse. I know, what i'm telling now is a very long time ago, but back in the very early 90's i purchased a Gas meter from a company called Instromet, located in Silvolde, NL. It had a pulse output and came completely with calibration certificates and all. You can see this gas meter here (notice the blue cable):
![Image](http://www.domoticaforum.eu/uploaded/Digit/20084401553_023_0002_filtered.jpg)
The complete package also included pressure meters, "rookgas" analysis stuff, to do efficiency calculations on Central Heating systems. The company still exists, so maybe just give them a call...
It's a long shot, but maybe worth a try.
