Watch out ! before upgrading Source !
Darwusch
Re: Watch out ! before upgrading Source !
Post by Darwusch »
Darwusch wrote:
Darwusch wrote:Same here.
I think it is because something is causing the source to eat the cpu.
Mostly when I open the standard plugwise webpage, the source takes about 80% of the cpu and this lasts until I restart the source.
It seems many strange errors are caused by the source not responding in time due to this.
For me, this problem started with the first 2.24 beta version and still present in current version 20140411.0
The extreme cpu usage due to the bug in this beta Plugwise, causes an increase of my PC server energy demand of 260 kWh yearly. :D
Just got a message from Plugwise (quick response btw):
Dank voor uw melding. Het probleem is ons bekend. We hopen het in de volgende beta opgelost te hebben.
Darwusch
Post by Darwusch »
In the latest beta they claim it is fixed, but it is not...
Beta version 20140613.0 still has the problem that the cpu usage grows to the maximum in a couple of hours.
The changelog says "Fixed - PTE: slow script execution and high CPU usage problem".
I sent them an email that the bug is still there, no answer yet.
T-Rex
Post by T-Rex »
Same for me, high CPU usage is still there with the latest Bèta (2.24beta(20140613.0)), also when the webserver is switched off.
Verkenner
Post by Verkenner »
I downgraded Plugwise Source to 2.23 20130901.2 (NON-Beta).
And HomeSeer Plugwise Plugin 2.1.0.0
This combi is working fine.
Best regards, Verkenner
T-Rex
Post by T-Rex »
Strange, the CPU usage just after starting the Source software is normal, like 2-6%. It looks like only after several hours the CPU usage starts to increase.
Darwusch
Post by Darwusch »
Exactly. Look at the graph I posted on page 1, you can see it increasing slowly.
Verkenner
Post by Verkenner »
Yes, a slow hangup.
Darwusch
Post by Darwusch »
Latest beta (20140729.1) seems to fix this.
I have been running it for 24 hours without an increase of cpu usage.
T-Rex
Post by T-Rex »
Same here. :)
vanisher
Post by vanisher »
any new beta's? the current one is expiring in a couple of days.
RdP
Post by RdP »
vanisher wrote:any new beta's? the current one is expiring in a couple of days.
Which version do you use? The latest of dated 15082014.
stefxx
Post by stefxx »
De updater shows no updates. But there is a new version available (the one that Rien mentioned): http://www.myplugwise.com/source/pwsetup_2.24beta.exe
RdP
Post by RdP »
In fact, now there is a 23092014 version.... Don't know what they changed in this version, but you can use it for another 59 days
Version 2.24 is in beta for more than a year now, which is way too lang if you ask me :-(
/Rien
Darwusch
Post by Darwusch »
Final 2.24 is out.
Post by Harry »
are there inportant changes? last time i upgraded i experienced mutch lost in functionality.... that a could buy back whith way to expensive licences :x what about this update,....is it a update or a downgrade?
Return to “Plugwise Forum”
