Toon App Idea: Cockpit / Dashboard
edwin999
Post by edwin999 »
Does the current Toon firmware support graphical UI elements like dials and gauges?
If so, can these can be used to create a cockpit style screen displaying i.e. water pressure and other boiler data?
Re: Toon App Idea: Cockpit / Dashboard
No, not at all. Here is a list of standard components you can use, but none of these is very fancy:
components_list.zip
(746 Bytes) Downloaded 407 times
edwin999
Post by edwin999 »
That's too bad, does the upcoming firmware 5.0 perhaps have new possibilities in this area?
no, more of the same. Just a newer QT version.
Return to “Toon miscellaneous”
