Does the current Toon firmware support graphical UI elements like dials and gauges?
If so, can these can be used to create a cockpit style screen displaying i.e. water pressure and other boiler data?
Toon App Idea: Cockpit / Dashboard
- qml-dialcontrol-example.png (33.04 KiB) Viewed 3819 times
- qtquickextras-example-dashboard.png (66.83 KiB) Viewed 3819 times
- gauge.png (4.74 KiB) Viewed 3819 times
Re: Toon App Idea: Cockpit / Dashboard
No, not at all. Here is a list of standard components you can use, but none of these is very fancy:
That's too bad, does the upcoming firmware 5.0 perhaps have new possibilities in this area?
no, more of the same. Just a newer QT version.
