thermostat resets to 10 deg after set temperature
basnijholt
Post by basnijholt »
I have bought an OTGW kit from Nodo Shop with a NodeMCU.
I am attempting to use the OTGW in combination with Home Assistant, which has an integration for it.
Unfortunately, I am experiencing problems (this issue https://github.com/mvn23/pyotgw/issues/11) with the pyotgw package (connectivity issues).
So I thought that I should find a lower-level solution, therefore I am trying `otmonitor` (which I then plan to connect to Home Assistant via MQTT).
Using `otmonitor` I do not seem to have the connectivity issues, however, I do notice something that also occurs when using the Home Assistant integration, namely, after each set control temperature command, the temperature resets to 10 degrees (see attached screenshot) before turning to the correct temperature.
I have also attached the logs for completeness (https://gist.github.com/basnijholt/1e81 ... 497f8ed0ef).
I have a Remeha iSense v27 and Avanta boiler.
Can anyone tell me if this is expected behavior or not? If not, how can I solve this problem?
Re: thermostat resets to 10 deg after set temperature
Yes, this is the expected (necessary) behavior, as I recently explained here: viewtopic.php?f=75&t=12623&p=92797#p92791
