Toon app: ToonStore
Re: Toon app: ToonStore
just deleting the folders is not enough. Toon still thinks buienradar is installed and therefor skips the installation of the ipk via ToonStore.
Remove buienradar with:
opkg remove buienradar
After that you can install again via ToonStore as usual.
Same for all other apps you had installed.
odelay99
Post by odelay99 »
Toonz wrote:just deleting the folders is not enough. Toon still thinks buienradar is installed and therefor skips the installation of the ipk via ToonStore.
Thanks Toonz, that fixed it!
Fietspomp
Post by Fietspomp »
I have a freshly rooted Toon with latest firmware, installed Toonstore but when I select an app and press "Toon bijwerken" nothing happens...
Also I can find a logfile to check for errors...
My second Toon also has the latest firmware and here it works fine.... Only difference between the Toons is the u-boot but this shouldn't matter I guess?
EDIT: Just saw my own Toon (one with trouble) had the time/date completely wrong (1st Jan 2011)... Apperently Chrony isn't really working.
Manuall set date and time and now it's working :oops:
Sorry, a bit late replying, you can find the correct config for chrony here: viewtopic.php?f=87&t=11449&p=85791&hili ... onf#p85791
BOverdevest
Post by BOverdevest »
Hi, I bought a freshly rooted Toon, everything seems to be working fine, except for the Toonstore.
I have the same problem as Fietspomp, when I select an app to be installed and press "Toon bijwerken" nothing happens...
I checked the time/date on the Toon and this is correct. So, it seems to be a different root cause...
Any ideas? Should I check/replace this Chrony script on the Toon?
greetings
Bart
B Overdevest
Rooted Toon, Raspberry 3B+, Domoticz
Could you post the toonstore log from /mnt/data/update/_opkg_<whatever>.log?
BOverdevest
marcelr wrote:Could you post the toonstore log from /mnt/data/update/_opkg_<whatever>.log?
Folder has 1 file only: _opkg.qb2-uni-9.9.99.script.sh
So no log file...
greetz
Bart
B Overdevest
Hi, can you check two things:
1. Is your hosts file correct ? (viewtopic.php?f=87&t=11756&p=83698&hilit=hosts#p83698)
2. Is your webserver running properly? (Start reading here: viewtopic.php?f=87&t=11756&p=83688&hilit=hosts#p83698)
BOverdevest
Toonz wrote:Hi, can you check two things:
1. Is your hosts file correct ? (viewtopic. ... sts#p83698)
i added to /ETC/host (so was missing)
172.20.48.1 feed.hae.int feed
After Toonstore was working properly
btw a # was added in front my line and the same line was added again the bottom of /ETC/host
Toonz wrote:2. Is your webserver running properly? (Start reading here: viewtopic. ... sts#p83698)
Correct it has the same URL reference?
I went through the posts, but i do not have the file /qmf/etc/qmf_project.xml
B Overdevest
Fietspomp
Post by Fietspomp »
Just out of curiosity, what firmware version do you have?
BOverdevest
Toon Software version 4.11.6
Is OK?
Sent from my iPhone using Tapatalk
B Overdevest
aabre
Post by aabre »
Hi Toonz,
Installed version 4.15.6
Globals.qml was overwrite by the install so toonestore was gone.
Add toonstore in Globals again and it look like its working again, only traffic app was not working anymore "traffic app is not working with the new firmware 4.15.6"
Also in toonstore the icons (+) and the refress ico was changed.
Is it possible to remove and install toonstore ? and will this help ?
tks Toonz
Gr. AadjeB
Hi reinstalling will not help. Both ToonStore and the traffic app will need an update to fix this.
Will do so but will go on holiday first.
Post by TheHogNL »
aabre wrote:Hi Toonz,
How did you upgrade? The update-script I have written will fix the Globals.qml right after the upgrade.
tks Toonz
Gr. AadjeB
I upgraded to 4.15.6 myself via de upgrade script from TheHogNl. Both ToonStore and traffic app are working fine here.
Just the 'refresh' picture is not shown on the ToonStore refresh button, but the refresh functionality works ok.
EDIT: For a day ToonStore blocked installation of apps because I hadn't updated the repo with the new available firmware version, probably that's why you have seen that icon (exclamation mark instead of a '+' sign).
