Central heating water pressure mqtt
timoline
Post by timoline »
Is it possible you add Central heating water pressure to mqtt?
timoline
Re: Central heating water pressure mqtt
Post by timoline »
Another request:
can you also add Remote override room setpoint (override) to mqtt?
tia
lsiepel
Post by lsiepel »
I'm missing more events like burnerhours/starts etc. It would be nice if OTGW monitor would post every message (with a changed value) to mqtt.
I tried to dig into the source code and i'm having trouble to figure it out. I think it has to do with the $signals object not containing all data items. But not familiair with the language and build environment.
# Publish all known persistent parameters
dict for {key args} $signals {
if {[llength $args] == 0} continue
set param [string tolower $key]
if {[info exists gui($param)]} {
mqttsignal $param $gui($param)
timoline
Post by timoline »
Yes, i just mentioned 2, but all events would be welcome ofcourse :-)
I'm waiting for a year now.....but I still hope it will be implemented eventually...
timoline wrote:I'm waiting for a year now.....but I still hope it will be implemented eventually...
I admire your patience to wait a year for someone else to do something for you. Of course you could also have spent a rainy afternoon to figure out how to do it yourself.
timoline
Post by timoline »
I wish I could, Ihen I had done it a long time ago. :D
But good to see you pushed it to github https://github.com/hvxl/otmonitor
It was just positive feedback to make OTGW better then it already is.
thx
timoline
Post by timoline »
Where in otmonitor.tcl can I do this calculation?
DeltaT = BoilerWaterTemperature - ReturnWaterTemperature
And put it in set signals, I assume...
timoline
Post by timoline »
ok, created a pull request to added some more mqtt events.
https://github.com/hvxl/otmonitor/pull/1
Hopefully it will be comitted soon
I merged your code and fixed some issues with it. I also added a deltatemp value.
timoline
Post by timoline »
wow great :-)
many thx
didnt checked it yet, but is deltatemp also send to mqtt?
It should now :)
anoppe
Post by anoppe »
This is nice, this will save me the effort to extract this data from the otgw by hand!
I've been able to compile the updated sources from Github into a binary that runs on my orange-pi otgw, and I've got several new topics available in my MQTT broker: https://imgur.com/a/Ej3oc8U
anoppe
Post by anoppe »
It seems to work as expected:
Screen Shot 2018-10-02 at 16.20.10.png (57.97 KiB) Viewed 12354 times
Thanks for the effort to create that PR @timoline!
timoline
Post by timoline »
hvxl wrote:It should now :)
looking good ! thx
