Someone has the new PMIX35 1.1.6 software?
Xanura said there is a new software version of the PMIX35 application. It is a new analysing tab. The software is not yet released on the Xanura website (www.xanurahome.nl) I don't know the reason why? Does someone know it and does someone have this version?
The new software is comming next month.
The are testing it now.
Software is nu te downloaden [:D]
http://www.xanurahome.nl/installateur/H ... fault.aspx
I just downloaded and tried the new PMIX35 software.
It installed without any problems on top of an existing installation of the previous version.
But beware: if you run it for the first time, it will immediately proceed to update the firmware of your PMIX35, without warning (nothing dramatic, but something you should know).
The new validation functionality (see screenshot) seems to be working well, but it does take some time and it will switch all of your devices on the selected house codes on and off - so please be careful with the electric chain saw behind the SAIX12
I still have to find out what exaxtly is happening during the validation test (it seems to be the A10 version of a ping), but for this house code everything is in the green, so I guess I did something right
Lennart
Lennart
And the sofware is gone form the site!
Does someone has a copy?
P
updated by admin
P
updated by admin
I have a copy, first have to find it, its on my USB stick but where is it
Lennart,
which version do you have?
is it 1.1.5 ?
is it 1.1.5 ?
My last version was 1.1.5, downloading now 1.1.6
thanks
thanks
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by binkiem</i>
<br />version 1.1.6 is still available
http://www.xanurahome.nl/installateur/P ... _1.1.6.zip
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Thanks
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">version 1.1.6 is still available<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I tried this version, but I'm having mixed feelings.
I only have a few modules in the house (mostly to test/experiment so 2 modules are still connected with a power cord to a wall outlet).
With some experimenting I found a few appliances which were disturbing the communications so those appliances have been moved to another "group" or put behind a wall-outlet filter.
So now I have 5 groups behind a powerline filter (SFX40) of which 3 groups are used the most (eg almost all lights, wall outlets etc are connected on those 3 groups), 1 group is not used at all and the last one only has the bell-transformer on it.
I have three modules connected, each on one of the 3 groups. With the PMIX35 software I can see the modules and connect them from (almost) every wall outlet. There are a few which are a bit wonky. The PMIX won't see all the modules if I use that wall outlet (eg only 2 from the 3 sometimes not even the module on the same group). Mostly it works when I put the PMIX on a long power extension cable.
So if I manually send commands ore request the status the modules will respond every time.
With the latest software I tried to "validate" the setup. What I found disturbing is that the software will first say "gevonden" than "mislukt" and then "controleer". If I look at the commands in the "analyzer" tab I can see the PMIX sends a few status requests when it first starts to "validate". Even though the module responds it will still say "mislukt" and later on "controleer" when it has finished with the module. For example this is the output of a module (a SAIX12):
Is this a problem in the software (and the reason it's not found on the site anymore) or is there something still disturbing the signals in our house? I hoped I'd found them all...
Module Tx OFF Tx ON Min Lvl Max Lvl Ruis Imp Resultaat
B01 3563 3547 6141 6710 419 17,1 Controleer
Let me check with Eaton, I think there is a reason why the software is not online anymore
Hi Pieter,
(Sorry for the late reply; I was out of network reach for a few days.)
The version I installed is 1.1.6. I haven't used the PMIX35 intensively since installing the new software, as I'm back to my CTX35 via a LAN interface for primary control.
I'm curious to know what the reason is for retracting this version...
Lennart
Lennart
Hi all
Version 1.1.6 is the latest PMX35 software
and here I have the manual for it http://www.bwired.nl/images/how/PMIX35116.pdf
In dutch a part of how the validate is working (sorry)
Validatie:
Op elk adres worden meerdere metingen uitgevoerd.
Eerst wordt gekeken of een module reageert. Dit wordt gedaan bij maximaal zendniveau (5Vpp).
Daarna wordt 4 keer het zendniveau verlaagd met 20%.
Als deze de eerste keer (bij 4,2Vpp) al niet meer reageert dan is de marge te klein en krijgt dit adres het stempel Mislukt.
Vervolgens wordt getest bij 3,5Vpp en 2,9Vpp.
Pas bij 2,5Vpp zendniveau krijgt deze het stempel Geslaagd anders wordt het stempel Controleer toegekend.
De testgrenzen zijn om precies te zijn
- >4,585Vpp: Mislukt
- <4,585Vpp en > 2,726Vpp : Controleer
- <2,726Vpp: Geslaagd
Verder wordt gekeken naar de ontvangen signaal niveaus:
- <100mV: Mislukt
- >100mV en <200mV: Controleer
- >200mV: Geslaagd
Validatie:
- <100mV: Mislukt
- >200mV: Geslaagd
Thanks for the info. The software does not behave as it states in the manual. At least it dowsn't show that way in the "Analyze" tab. Attached I've sent a "validate" log from the B01 module. The first few status requests are made by me. The first on (on full power) works OK; the second one (at 0,8V) does not work. I then try a few times and the tipping point is around 1V. Below the module does not respond, above it will send the status as requested.
Then at 18:54 I started the validate. According to the log they try with 4,5V, 5V, 6,2V, 5,2V, 4,3V, and 3,7V signal. All requests are answered by the module. So that is why I don't understand the software says it's "mislukt". It didn't even try lower than 2,7V....
[edit]The attachment does not seem to come through so here it is:
Datum Tijd Spatie Data 1 Voltage 1 Ruis Niveau 1 Data 2 Voltage 2 Ruis Niveau 2 Netwerk Impedantie Status Echo
22-9-2008 18:52:53 S B01 7474 402 17,3 Echo
22-9-2008 18:52:54 S BSRQ 4470 426 17,3 Echo
22-9-2008 18:52:54 S B01 6668 390 B01 6674 387 17,3 No Echo
22-9-2008 18:52:54 S BSOF 6673 384 BSOF 6680 387 17,3 No Echo
22-9-2008 18:53:00 S B01 1308 407 17,3 Echo
22-9-2008 18:53:01 S BSRQ 885 427 17,3 Echo
22-9-2008 18:53:06 S B01 1855 397 17,3 Echo
22-9-2008 18:53:07 S BSRQ 1217 421 17,3 Echo
22-9-2008 18:53:07 S B01 6448 401 B01 6422 401 17,3 No Echo
22-9-2008 18:53:07 S BSOF 6406 408 BSOF 6387 421 17,3 No Echo
22-9-2008 18:53:17 S B01 1469 377 17,3 Echo
22-9-2008 18:53:17 S BSRQ 1035 365 17,3 Echo
22-9-2008 18:53:18 S B01 6436 401 B01 6441 413 17,3 No Echo
22-9-2008 18:53:18 S BSOF 6427 420 BSOF 6417 425 17,3 No Echo
22-9-2008 18:53:26 S B01 1159 404 17,3 Echo
22-9-2008 18:53:27 S BSRQ 896 377 17,3 Echo
22-9-2008 18:54:03 S B01 4495 407 B01 4489 393 17,1 Echo
22-9-2008 18:54:04 S BSRQ 4496 372 BSRQ 4497 386 17,1 Echo
22-9-2008 18:54:04 S B01 6691 398 B01 6705 399 17,1 No Echo
22-9-2008 18:54:05 S BSOF 6726 380 BSOF 6702 385 17,1 No Echo
22-9-2008 18:54:06 S B01 5068 401 B01 5074 395 17,1 Echo
22-9-2008 18:54:06 S BSRQ 5063 427 BSRQ 5077 425 17,1 Echo
22-9-2008 18:54:07 S B01 6671 407 B01 6663 410 17,1 No Echo
22-9-2008 18:54:07 S BSOF 6653 417 BSOF 6636 408 17,1 No Echo
22-9-2008 18:54:08 S B01 6249 401 B01 6284 406 17,1 Echo
22-9-2008 18:54:08 S BSRQ 6254 420 BSRQ 6250 422 17,1 Echo
22-9-2008 18:54:09 S B01 6522 412 B01 6528 409 17,1 No Echo
22-9-2008 18:54:09 S BSOF 6506 414 BSOF 6514 415 17,1 No Echo
22-9-2008 18:54:10 S B01 5253 390 B01 5259 393 17,1 Echo
22-9-2008 18:54:10 S BSRQ 5274 367 BSRQ 5265 377 17,1 Echo
22-9-2008 18:54:11 S B01 6955 398 B01 6962 398 17,1 No Echo
22-9-2008 18:54:11 S BSOF 6951 384 BSOF 7013 391 17,1 No Echo
22-9-2008 18:54:12 S B01 4382 401 B01 4387 386 17,3 Echo
22-9-2008 18:54:13 S BSRQ 4376 383 BSRQ 4399 377 17,3 Echo
22-9-2008 18:54:13 S B01 6466 394 B01 6459 391 17,3 No Echo
22-9-2008 18:54:14 S BSOF 6470 392 BSOF 6445 382 17,3 No Echo
22-9-2008 18:54:14 S B01 3697 397 B01 3673 393 17,3 Echo
22-9-2008 18:54:15 S BSRQ 3683 406 BSRQ 3656 420 17,3 Echo
22-9-2008 18:54:15 S B01 6358 402 B01 6353 394 17,3 No Echo
22-9-2008 18:54:16 S BSOF 6331 412 BSOF 6337 415 17,3 No Echo
22-9-2008 18:54:18 S B01 7472 409 B01 7470 407 17,3 Echo
22-9-2008 18:54:18 S BON 7472 404 BON 7463 411 17,3 Echo
22-9-2008 18:54:20 S B01 4472 393 B01 4471 401 17,3 Echo
22-9-2008 18:54:20 S BSRQ 4492 374 BSRQ 4487 368 17,3 Echo
22-9-2008 18:54:21 S B01 6967 393 B01 6979 388 17,3 No Echo
22-9-2008 18:54:21 S BSON 6983 380 BSON 6994 384 17,3 No Echo
22-9-2008 18:54:22 S B01 6248 403 B01 6251 405 17,3 Echo
22-9-2008 18:54:22 S BSRQ 6236 422 BSRQ 6253 411 17,3 Echo
22-9-2008 18:54:23 S B01 6513 398 B01 6513 414 17,1 No Echo
22-9-2008 18:54:23 S BSON 6494 415 BSON 6486 418 17,1 No Echo
22-9-2008 18:54:24 S B01 5249 399 B01 5241 418 17,1 Echo
22-9-2008 18:54:25 S BSRQ 5233 418 BSRQ 5223 424 17,1 Echo
22-9-2008 18:54:25 S B01 6447 413 B01 6473 410 17,1 No Echo
22-9-2008 18:54:25 S BSON 6472 403 BSON 6461 410 17,1 No Echo
22-9-2008 18:54:26 S B01 4376 408 B01 4376 393 17,1 Echo
22-9-2008 18:54:27 S BSRQ 4356 423 BSRQ 4376 421 17,1 Echo
22-9-2008 18:54:27 S B01 6420 410 B01 6429 401 17,1 No Echo
22-9-2008 18:54:27 S BSON 6417 416 BSON 6398 421 17,1 No Echo
22-9-2008 18:54:28 S B01 3667 402 B01 3678 400 17,1 Echo
22-9-2008 18:54:29 S BSRQ 3650 426 BSRQ 3660 408 17,1 Echo
22-9-2008 18:54:29 S B01 6352 402 B01 6347 404 17,1 No Echo
22-9-2008 18:54:30 S BSON 6356 416 BSON 6878 417 17,1 No Echo
22-9-2008 18:54:31 S B01 7465 400 B01 7497 392 17,1 Echo
22-9-2008 18:54:31 S BOFF 7491 404 BOFF 7486 393 17,1 Echo
22-9-2008 18:54:33 S B02 4489 395 B02 4483 388 17,1 Echo
22-9-2008 18:54:33 S BSRQ 4512 385 BSRQ 4519 371 17,1 Echo
22-9-2008 18:54:37 S B03 4480 397 B03 4466 402 17,1 Echo
22-9-2008 18:54:37 S BSRQ 4491 373 BSRQ 4491 374 17,1 Echo
