I have tried to root my Toon2.
- Recovery to 4.9 firmware.
- Root-A-Toon-USB-Stick
but it always seems to fail.
I then updated the firmware to 6.3.91
With this firmware installed i can run Root-A-Toon-USB-Stick and it works flawlessly and repeatedly.
However, due to missing resource files there is no Toonstore.
FIXING: Downloading resources.rcc TSC mod for this version 6.3.91.
[ERROR] Could not download a resources.rcc file for this version! Continuing, but your custom apps probably dont work anymore
I tried the whole recovery to 4.9 process a couple of times but for some reason it just does not pick up.
I am now on 6.3.91 with root access, all seems to work well but of course no toonstore.
I can login via SSH but running the upate-rooted.sh -F on the toon gives the same resource file error. Which makes sens as the version is not in the list.
Only fixing files.
creating backup of inittab...
creating backup of hosts...
EDITING: add disable power management wifi on Toon2
EDITING: add autobrightness feature on Toon2
EDITING: disabling Eneco subscription feature apps which are not working on rooted toons
EDITING: lighttpd so tsc/sensors is viewable via a browser
Finished fixing files!
Is there a way to install the toonstore manually?
Is there a way to downgrade to a supported firmware version?
Or is the only way to keep on trying with the 4.9 firmware?
thanks for any hints or tips..
