A few months ago I bought the LAN 2 port 433.92MHz RFXmitter for homeseer. (Item Number 89004)
I am using this in a successfull way with my Harison Curtains at the moment.
Now I want to measure temprature & power with the RFXPower & RFXMeter devices.
Does this mean I need to buy the:
- 433.92MHz receiver 2 ports LAN interface (Order code: 83003)
- 433.92MHz RFXMeter with 1 RFXPwr module 230V/50Hz (Order code: 70087)
OR
- 433.92MHz RFXMeter with 3 RFXPwr modules 230V/50Hz (Order code: 70088)
The RFX meter type will depend if I need the 1 Phase or 3 Phase.
For the temprature measuring I need the:
- 433.92MHz RFXSensor Type-3 with temperature sensor (Order code: 40066)
- External temperature sensor (Order code: 60010)
I can not (re)use the RFXmitter to measure power and temrature right?
And is the list I posted above a correct list or am I missing something?
Thansk,
Iwan
What do I need to measure temprature & power?
I was just reading this on http://www.domoticaforum.eu/topic.asp?TOPIC_ID=1475
That if you have the LAN 433,92 Mhz Transmitter you have the option to have 2 receivers and 1 transmitter.
This means that I only need this right? --> 433.92MHz MASTER receiver module for X10 and others Order (code: 40071)
In order to use the RFXPwr & RFXMeter.
Am I correct?
Thanks,
Iwan
Am I correct?
Thanks,
Iwan
- b_weijenberg
Please send configuration questions to support rfxcom.com.
You can order the 433.92MHz receiver module and insert that module in your 2 port LAN interface. When you order this receiver module you have to send an email to sales rfxcom.com that you need a Master version of the 80011!!!
http://www.rfxcom.com/receivers.htm#80011
Note: the 40071 cannot be ordered as 1st receiver. This receiver is only delivered for replacing an existing receiver module.
If you have a 3-phase system you need the 70088
http://www.rfxcom.com/sensors.htm#70088
RFXSensor:
http://www.rfxcom.com/sensors.htm#40066
wired additonal sensor:
http://www.rfxcom.com/sensors.htm#60010
or http://www.rfxcom.com/sensors.htm#60011
The accuracy of the 60010 is a little bit better but does not have the A/D sensor.
RFXSensor:
Ok I understand the Receiver part now and that I will need the Master version of the 80011 that will fit into my 2 port LAN interface.
I also understand the power measurement is done trough the 1-phase system (70087) or the 3-phase system (70088)
Now the Temprature stuff is a bit unclear for me.
If I want to measure:
- temprature
- humidity
I will need the http://www.rfxcom.com/sensors.htm#60066
Am I correct?
Now what do I need in total? if I want to:
- measure the temprature in room 1 within the house
- measure the temprature in room 2 within the house
- measure the temprature in the garden outside the house
- measure the humidity in room 1 within the house
- measure the humidity in room 2 within the house
- measure the humidity in the garden outside the house
Thanks,
Iwan
- temprature
- humidity
Am I correct?
Thanks,
Iwan
- b_weijenberg
40066
add a 60010 (or 60011)
measure temperature AND humidity:
60066
add a 60012
add a 60012
40066
60066
add a 60012
add a 60012
So when I want to measure temperature AND humidity inside (2 rooms) and outside
I only need 60066 and 2 x 60012.
Correct?
Thanks,
Correct?
Thanks,
- b_weijenberg
