Changed to Dim (or level change)
Alexander
Post by Alexander »
Anybody uses this status change trigger type? If so did you noticed the "or level change" will not fire if you are already in de Dim state?
Example:
1. light is off
2. dim the light to 50% -> triggers event based on this type of status change
3. dim the light to 30% -> the event will not be triggered
So is it a bug or don't i understand the "or level change" correctly?
Alexander
Alexander
Re: Changed to Dim (or level change)
Post by Alexander »
Somebody?
Alexander
