I'm a complete newbie to HA, have been watching from the sidelines for a good number of years and have finally taken the plunge... I've built a DomotiGa server on a sheevaplug.....and purchased an RFXCom to initially go with some HomeEasy switches.....
The sheevaplug is running kernel 2.6.39.4, and 9.04.
dmesg gives:
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for FTDI USB Serial Device
ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
usb 1-1: Detected FT232RL
usb 1-1: Number of endpoints 2
usb 1-1: Endpoint 1 MaxPacketSize 64
usb 1-1: Endpoint 2 MaxPacketSize 64
usb 1-1: Setting MaxPacketSize 64
usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
NET: Registered protocol family 10
eth0: no IPv6 routers present
2012/04/08 14:49:35 RFXCom transceiver support enabled.
2012/04/08 14:49:35 RFXCom transceiver Error: Cannot open serial port (#5) at CRFXCinTRX.ConnectSerial.418
2012/04/08 14:49:35 ERROR: RFXCom transceiver serial interface FAILED to connect to Port /dev/ttyUSB0
2012/04/08 14:49:35 RFXCom transceiver Relay disabled
Is there anyway I can test the transceiver from the command line to check all is well before I start looking into domotiga?
Thanks
James
